Discussion topic: Sky Go will not work on MacBook Pro
Message posted on 16 Feb 2021 05:08 PM
							Re: Sky Go will not work on MacBook Pro
Message posted on 16 Feb 2021 05:10 PM
Also remove an old Sky go first. do this from finder. close Mac down after removing all copies then reinstall from link
Message posted on 16 Feb 2021 05:11 PM
Will give it a go now - thanks.
Message posted on 16 Feb 2021 05:30 PM
Thanks @seandouglas2 - had another go, removed old apps and downloader apps, restarted, re-downloaded from the link (same website I tried previously), and failed again.
It starts the download, goes straight to an update, then tells me to "Quit and Continue Installation" thinking the App is running somewhere when it is not.
Frustrating, but thanks for your suggestion.
Message posted on 16 Feb 2021 06:16 PM
@GJ+Spearing you mac is updated? i would try using spotlight to find the other Sky go
Message posted on 16 Feb 2021 07:07 PM
Thanks, I did search via spotlight, removed installer download and App, still no joy.
Mac upated earlier today.
Message posted on 16 Feb 2021 07:22 PM
Just deleted all apps and download installers, rebooted, did the same install as previously (about 15 attempts in total) and it worked after about 3 more attempts.
Something is just not right but I do now have SkyGo - no idea how, as the install was the same as previously.
Thanks for your help @seandouglas2 - for anyone else with the same issue - perseverence, keep removing old version of SkyGo, including installer downloads, then re-boot and try again. Must have been 15-20 attempts but finally working again.
Message posted on 17 Feb 2021 06:25 PM
My Skygo also works now, I think it must have had a serious blip, just when we wanted to access it yesterday.
Message posted on 06 May 2021 07:23 PM
Yet again, Sky Go has stopped working on my MacPro. I get z message to say an update is being downloaded and then the app closes.
I have no problems whatsoever with the BBC, ITV, Channel 4 or Netflux apps but continually problems with the Sky Go app.
It is an absolute disgrace and whoever is responsible for maintaining this app should be fired - they are totally incompetent.
Message posted on 06 May 2021 07:30 PM
Try this to completely remove it before installing it again:
Delete the Sky Go app.
Launch Finder, select Downloads then delete ‘SkyGoInstaller’.
Launch Finder again, select Go (at the top of the screen), then Computer.
Select Macintosh HD.
Go to Users > [yourusername] > Applications then delete the Sky Go app.
Then go to Library by Open Finder.
Click "Go" on the menu bar.
Press and hold the “option/alt” key.
Click the "Library" shortcut which appears.
Then navigate to the relevant folders (Application Support, Caches or Preference) and delete all SkyGo folders and files referencing Cisco player
Reboot your Mac and then download and install the Sky Go app again.
Message posted on 06 May 2021 07:31 PM
Thanks - will give it a try.
Message posted on 02 Jun 2021 05:10 PM
Message posted on 28 Oct 2021 12:04 PM
Recently got a new MacBook Pro 14 with an M1 Pro processor. This MacBook was also migrated from an old MacBook. Sky Go wasn't installing at first but these steps allowed me to install Sky Go properly. Thank you! I've seen some people say to make a new user and transfer all your data to that, but try this first everyone as this worked for me!
Message posted on 28 Oct 2021 02:53 PM
@caesarome's tips of removing Sky Go properly solved it.
