The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
09 Jun 2022 01:55 PM
Had to use the iPad version of Sky Go last night for the first time since moving to Sky Q.
Shortly after launching it says "We've found a different Sky Q Box" and gives yuo the option to CONNECT or DONT CONNECT.
I hit connect, but a few seconds later I get the same message.. And this happens over and over and over.
In contrast the PC version on the same network connects fine..
Any thoughts?
10 Jun 2022 11:33 AM
Posted by a Sky employeeIs the ipad on the latest software?
10 Jun 2022 11:38 AM
That was my first thought... I wasn't, but I downloaded the latest and its the same.
10 Jun 2022 01:32 PM
Posted by a Superuser, not a Sky employee. Find out moreIn the settings of the Sky Go app is the connection to your Q box turned on or off ?
10 Jun 2022 01:34 PM
On.. And on my PC running the desktop version of SkyGo it picks up the SkyQ box just fine
10 Jun 2022 01:36 PM
Posted by a Superuser, not a Sky employee. Find out moreHave you tried leaving it turned off perhaps overnight or some other time you are not using it then turning back on when you come to use it next ?
10 Jun 2022 01:37 PM
Tried that...
13 Jun 2022 11:57 AM
Any more ideas??
13 Jun 2022 12:00 PM
I just installed SkyQ on my Android Phone and it works just find.. It sees the SkyQ box (it doesn't actually ask to connect like the iPad app does).. And I can see the recordings
This is the same network so this is clearly an iPad/App thing...
13 Jun 2022 01:25 PM
Posted by a Superuser, not a Sky employee. Find out moreAll I can suggest is to email the apps team to see if they have any ideas:
apps@sky.uk
