24
Discussion topic: Setting up Sky Broadband
Locked
This message was authored by Shazzykane This message was authored by: Shazzykane
Re: Setting up Sky Broadband
A dont know how to set my sky up broadband up
@Shazzykane
What router do you have?
Are you on superfast fttc or ultrafast fttp?
Is today your activation day ?
@Shazzykane
The cable jammed into the yellow port looks incorrect: that's an ethernet port and shouldn't have a phone lead plugged into it.
https://www.sky.com/help/diagnostics/set-up-your-sky-hub/which-sky-hub-do-you-have
A dont have a house phone
@Shazzykane
Could you post a picture of the wall socket, please?
Then at least two of those cables shouldn't be there...
A took that wire out because a dont have a house phone
@Shazzykane
There also shouldn't be a cable in the socket marked 'Italia/ROI': that's for a phone handset in those countries.
If you could post a picture of the phone box on the wall, that would help.
Are you definitely a Sky Broadband subscriber at that address and have gone past the activation date?
Locked
