Discussion topic: STVHD not available but other channels are, says no satellite signal
Message posted on 15 Nov 2021 07:07 PM
I cannot access STVHD, I live in a Glasgow postcode, says no satellite signal but all other channels are fine. It's happened in the past but this time it's been unavailable for much longer, weeks. Any suggestions?
Message posted on 15 Nov 2021 07:10 PM - last edited: 15 Nov 2021 07:12 PM
Re: STVHD not available but other channels are, says no satellite signal
What are the Signal Strength/Qualities in the Sky Box setting when it's tuned to an affected channel?
Message posted on 15 Nov 2021 07:35 PM
I'm not sure how to 'read' the signal but the input 1 strength and quality are about 60% input 2 signal strength the same but the quality has a very low bar
Message posted on 15 Nov 2021 07:40 PM
Unscrew both the cables from the back of the box, swap them over ans screw then back in (hand tight), then re-check the signal/qualities and see if they have improved
If this does not help then you'll need to call someone out to take a look
