This discussion topic is read only Discussion topic: Re: Viewing Card Not Authorised
This message was authored by: noskydea
hello i'm having the same problem - whatever i record on catchup won't play and sends me to an error message SPC10 saying it can't play the recordig and then telling me to check my card is inserted (it is). pause works fine. can you help? thanks
Locked
@noskydea wrote:
hello i'm having the same problem..
This thread relates to a 'viewing card not authorised' error message. Is that the error message you're seeing?
Avatar for noskydea
it says 'We cannot play this recording' and tells me to press the yellow button for help with the SPC10 in the top right hand corner.
when i press the yellow button, i get a message saying 'This service is currently unavailable. Please check your Sky viewing card is inserted and try again later' with an OK button and no other information.
This message was authored by: Rhonny
@noskydea
Do you have Sky+, not Sky Q?
Avatar for noskydea
Yep, Sky+.
This message was authored by: Kenny-J
This error is a Sky+ HD error, have you replaced your box with this one recently? Perhaps someone has given you their old box?
Ultimately what ever the answer I think the only solution will be to go into the hidden menu and format the hard drive.
Kenny
Locked
