Discussion topic: Part-watched recorded programme disappears when switching back to it from to live TV.
This message was authored by leighk2 This message was authored by: leighk2
Hi,
I've had this happen several times. I'm watching a recoded programme on my Sky-Q box and then part way through I switch to live TV to watch the News, when I switch back to trying to watch the rest of the recorded programme it has either completely dissapeared or has skipped to the end with no way of rewinding it which is really annoying. This has started to happen recently, before I could switch back and watch the remainder of the programme.
Any help much appreciated thanks.
Locked
Re: Part-watched recorded programme disappears when switching back to it from to live TV.
@leighk2 wrote:
Hi,
Hi @leighk2
Try a Reset Settings in the hidden menu.
Press 1 & 3 together on the remote and follow onscreen instructions to re pair.
leighk2
Hi,
Many thanks for the quick reply, I'll give it a try.
Kind regards
Locked
