This discussion topic is read only Discussion topic: Panther Problems Continue!!!
Locked
This message was authored by: mally+01
Re: Panther Problems Continue!!!
@Anonymous
What yours itv like
@Anonymous
Is it worth it ?
Are you talking about linear as in ITV1 or ITV Hub. My linear ITV1 is Meridian, I live in Essex, it's absolutely fine, comparable to Q. ITV hub is poor in SD.
@Anonymous
Is it worth it the sky glass
@Anonymous
Also are you streaming through sky or by the aerial
Not really sure what you mean. sky glass is a streaming service. The aerial only works when you have no Wi-Fi.
@Anonymous
Do you think it is worth the money
Jury is out to be honest. I was paying £33.00 less for Sky Q - on very similar channels/options. It's early days, sky will make the required changes and it will be a good product. If you can afford it get it - if cash is tight, stay with Q for a couple of years, until the new product tax has come off and sky offer discounts on Glass is my advice
@Anonymous
Mine is hopefully coming on Tuesday
It was meant last friday
Make sure you physically check the tv. Mine had a screw that was half way unscrewed in the bottom corner.  Also my sensor doesn't work.
@Anonymous
Yeah they have said the motion has not been switched on yet will they do they might be a charge.
@mally+01 i am afraid what you are saying is completely incorrect. Motion should be working on all glass sets and there is no charge for it. My set maybe faulty or needs a software change.
This message was authored by: AaronC88
@Anonymous @mally+01 @@Yes technically you do pay for this feature it's part of the base pack. If you was to cancel it would stop working
This message was authored by: DynamoHummer
Motion works for me now..
@AaronC88
What do you mean base pack
Locked
