Discussion topic: No Live Channels/Channels freezing on Glass & Stream 4/6
Message posted on 04 Jun 2023 11:26 AM
Re: No Live Channels/Channels freezing on Glass & Stream 4/6
@Leslie2309 @Stulaw72 I have merged your post to this existing thread that is discussing the issue.
Getting no live tv channels..getting waiting for programe to load and then techinal error with channel....im on the q17 software
Glass
Sky glass not working again
Message posted on 04 Jun 2023 11:27 AM
Clearly a very big issue, just a blank screen here, then a picture freezes no sound . What a nightmare.
Message posted on 04 Jun 2023 11:28 AM
Can’t load channels
Can't load channels is there a fault at skys end
Same issue here in Nottingham with streaming. Tried rebooting Puck which normally do and normally sorts it, but no luck today. Tried the other puck we have thats in different room and same black screen on live channels.
Wi-Fi connection ok and all apps working well so just the live TV.
Only had the pucks less than a month and not been very impressed so far as had few issues of black screens though this is longest so seems to be problem with sky rather than pucks this time.
Can’t get any channels on my sky glass
I have no channels on my sky glass,when they do load they freeze or just shut down
Message posted on 04 Jun 2023 11:29 AM
I had the same thing yesterday (apps all working and streaming fine in HD but Sky delivered content not) & troubleshooting over the phone, the operative is also sending me a new puck to exchange for this one but after this I did some further research and testing
In my case I switched from my router on my own internet connection in my room to the main one in the house, and it started working again. My issue was a bit different from yours in that the symptoms are the same but the cause slightly different, although I think this may shed some light on what may be happening and someone from Sky will hopefully be able to confirm the situation.
In my case I'm was using an EE 4G router which is permanently connected, however EE use something called CGNAT (to save on the number external of IP addresses they need) which means that services (such as Sky Stream) connected to do not see a unique IP address for the device connecting, and the other thing is that when I phoned back and mentioned I'd got it working, the Sky operative asked me whether my external IP address is static (i..e. it never changes) or DHCP assigned (i.e. it changes every so often). I explained the situation and she mentioned that there is a fair bit of security around the service to ensure that it is only being used in a single residency (and not being moved between households) in accordance with the terms and conditions, and that I would be best to keep using my parents BT ADSL internet connection (the reason I have my own 4g modem is that the ADSL is not as fast as the 4G) as that is what the Sky Stream systems are expecting (i.e one customer on a unique IP address which changes from time to time when the DHCP renews).
I appreciate though that most people won't be using 4G or there might be different issues ongoing at the moment from what I experienced yesterday but the part that might be relevant to most people is, one of the official troubleshooting steps includes rebooting the router, I think the reason for this could be that as well as being a standard thing to do to resolve connection issues is that it also causes the router to obtain a new/different external IP address from the internet service provider and potentially it could be that this change of IP address causes the service to start working again for the customer. Therefore I'm wondering whether the service stops working if a Sky Stream customer has been using the same IP address to connect to the service for longer than a set amount of time (triggering a need to reboot the router) Obviously this is only a theory, but it would be interesting to know if this is the case - please could anyone from Sky confirm? Thanks
Message posted on 04 Jun 2023 11:29 AM - last edited: 04 Jun 2023 11:32 AM
Sky have confirmed there is an issue and are working on it
https://twitter.com/SkyHelpTeam/status/1665303676053860352?s=20
Thanks,
Tim
Sky stream not working
My sky tv is not working
Glass not loading
Sky glass not loading programs but will let you watch catch up etc tv message says programs load but never loads I have rebooted router and done all the checks Internet no problems wifi no problem HELP please
Message posted on 04 Jun 2023 11:30 AM
Glass not working
Why is glass not working yet again cant get any programme money well soent again
Tv
Sky glass keeps freezing, turning off . I've tried unplugging it but nothing seems to work
Message posted on 04 Jun 2023 11:32 AM
'Please wait for your programme to liad'
Keep getting the message 'please wait for your programme to liad' when trying to access any channels on Sky glass. Other applications, such as Netflix, Prime etc working fine, just seems to be Sky TV channels.
If programme loads it just freezes on a still image.
Have tried resetting router, switching Sky glass TV off etc.
