295
This discussion topic is read only This discussion topic has been answered Discussion topic: No Live Channels/Channels freezing on Glass & Stream 4/6
Locked
This message was authored by: Tim+Adams
Re: No Live Channels/Channels freezing on Glass & Stream 4/6
Hi @SGB
Who is your broadband supplier?
Thanks,
Tim
Sky Glass with Sky Live, Sky Stream & Sky Protect - FTTP 2Gbps
This message was authored by: SGB
Hi I am on EE 4G
I have just done the turn off power to puck, turn off power to router, restart router, restart puck and now all running fine!
@SGB wrote:
Hi I am on EE 4G
Hi @SGB
Thanks for confirming and posting back.
Thanks,
Tim
This message was authored by: Kel36
I have done all of the above the screen is now stuck on updating software doesn't look like it's doing anything tho 😞
This message was authored by: DaveLancs
Just received replacement puck but this new one is also having the issue. My ISP is BT.
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent Kel36 an invite.
Hi @DaveLancs
What message are you seeing?
Thanks,
Tim
@Tim+Adams  the message on screen is "Please wait for your programme to load."
then it drops back out the menu after a while. I've tried streaming from within iPlayer and other apps and it seems fine. The issue seems to be specific to content delivered directly from Sky, cheers
Hi @DaveLancs
Thanks for that, what speed do you get if you do a Netflix speed test via the app?
Open Netflix on Stream
From the Netflix homescreen, go left to open the menu.
From the bottom of the menu, go right and select Get Help.
Select Check your Network.
Thanks,
Tim
Hi @Tim+Adams
Ive just switched back to my EE 4G home router to see if it is network/ISP specific (further details in my post here https://helpforum.sky.com/t5/Glass-Stream/No-Live-Channels-Channels-freezing-on-Glass-amp-Stream-4-6...) and still getting the same issue. The speed test shows 58 Mbps as per photo below, cheers
Hi @DaveLancs
Which connection is the one you use with Stream? When you switched connection did you also turn the Stream off at the socket, wait a min then back on?
Thanks,
Tim
This message was authored by: Jmac136
Does anyone know how long it usually takes for updates to be fully deployed? (based on past updates) It seems people were getting QS18 from around the 31st, I've still got constant issues with Glass and needing to reboot multiple times a day, and the TV hasn't updated yet : (
Hi @Jmac136
Updates are usually completed over a few weeks.
Thanks,
Tim
This message was authored by: Lisa-P1987
Update - Spoken to Kel36, they advised the issue is resolved 🙂
Lisa - Sky Tech Team Expert
Thanks for help all 😊
Locked
Answered - Go to Answer
