This discussion topic is read only Discussion topic: Netflix not working on main TV but works on other TVs
This message was authored by: DiMo1
Netflix has stoppped working on my main TV - Netflix error tvq-pb-101(5.6.0).  Netflix still works on my other 2 TVs!  I have noticed the Netflix ESN is different on the main TV to the other 2.  Any ideas how I get the ESN to be the same again on all 3 so that Netflix will work?
Locked
Avatar for DiMo1
Re: Netflix not working on main TV but works on other TVs
I should that I have Sky Q!
This message was authored by: fizzdisco
@DiMo1
Are you accessing Netflix via the Sky Q Netflix app? Are you saying that you can access the app on two Sky Q miniboxes but not on your main Sky Q box?
Try fully rebooting your main box - ie turn off at the wall for 30 seconds then power back on.
Avatar for DiMo1
 fizzdisco, thanks for your reply I am saying exactly that and I have tried rebooting and it makes no difference.
This message was authored by: TechmanagerMal
Passing on the tips I have learned in over 25 years as a more than satisfied Sky customer.
Avatar for DiMo1
This has been answered by phoning Sky tech support, very helpful
Locked
