269
This discussion topic is read only This discussion topic has been answered Discussion topic: Live TV: There's a technical fault with the channel/Please wait for the programme to load
Locked
This message was authored by: StoopR
Re: Live TV: There's a technical fault with the channel/Please wait for the programme to load
Hope I'm not speaking too soon but mine seems to be working properly. Normally I have to restart 10-15 times a day but today every sky channel has worked throughout multiple shows and adverts. Maybe the problem wasn't QS017 and actually something on Sky's side and they've managed to fix it?
This message was authored by: Redderz27
@StoopR
1 in the bedroom went off at 9am and 1 in the mancave went off an hour ago for the 4th time today this is a joke, I'm luckily in my cooling off period so I'll be getting rid, hopefully you'll have success 🤞
@StoopR Maybe you are lucky and have already been updated to QS017.005.02P which started to rollout last night. This is specific to pucks and should resolve some of the recent issues.
You can check at Settings > system management and look at the build version.
I've just checked and you're correct!
This message was authored by: Walkabout+syd
@StoopR spoke to a sky advisor today very helpful overnight apparently a new version for the sky stream puck was downloaded version Qs017.005.02p should fix this issue scroll to bottom of screen to find settings then system management to see what system you are on if you are not on latest system you will have to wait for the latest download from sky
Yep, that's sorted it for me. Currently on the new update.
This message was authored by: Deeefa
@StoopR Just checked mine, and not on that version yet. Will keep checking and hope this fixes my issues.
This message was authored by: amagluglug
Re: Live TV: There's a technical fault with the channel. Try again later
Has there been an update on the wait for your programme to load then technical fault screen on live tv?
@amagluglug an minor update specific for Stream pucks  (QS017.005.02P) started to be rolled out last night which seems to be fixing some of the current crop of faults puck issues.  The roll out will of course take a few days to complete so it a question of waiting with fingers crossed.
I had the same issue with the Sky Puck, the same messages. It was annoying. I solved the problem using an ethernet cable direct from your router to the TV, Its works fine. The WiFi alone doesnt seem strong enough to  work with the Puck even with a decent signal.or speed.
This message was authored by: Unisoft
Brand new customer to Sky from Virgin Media where their Stream product is actually good and works. Came to Sky as more channels available albeit £29 monthly rather than £8 (actually VM take 10% off as well fir customers so £7.20).
Anyway got 1gbps broadband and wifi ax in greenfield site getting around 470mbps upstairs.
Plagued by random Technical trouble with the channel and Please wait for the channel to load on my new Sky Stream puck.
Software version is QS017.005.00P
Is there any way to ask for feature requests to Sky Stream too?
That's not either of the most recent releases.
It's what it updated to 5 days ago when it was new from Sky. Doesn't seem to be an option in Settings to Check For Updates.
Sky says:
To run a software update:
  1. Switch the Sky Glass or Sky Stream puck to standby.
  2. Switch it off at the mains and unplug it.
  3. Plug it back in and switch it back on at the mains.
  4. Leave the Sky Glass or Sky Stream puck powered on for 30 minutes.
  5. After 30 minutes, switch the Sky Glass or Sky Stream puck to standby again.
  6. Switch it off at the plug and switch it back on again. There’s no need to unplug it this time.
  7. Press the Home button on the Sky remote.
After a few seconds, the Sky logo will show on screen as the TV or Sky Stream puck starts back up. The software version will now be updated to the latest version.
This message was authored by: Citrax
Mine is now showing QS017.005.02P.
Looks like there has been an update.  Thinking about it I've had no issues at all today 🤔
Locked
Answered - Go to Answer
