This discussion topic is read only Discussion topic: Landline not working,can't get in touch with sky to fix or cancel
This message was authored by: jake+1507
Landline not working,sky not answering,need it fixed or cancelled
Locked
Re: Landline not working,can't get in touch with sky to fix or cancel
@jake+1507
This troubleshooting link may help https://www.sky.com/help/diagnostics/fix-problems-with-your-phone/check-your-phone-line
If that advice and link doesn’t help, post back on here and some of us here will be able to escalate your problem to Sky. If/when a fault is diagnosed Sky will pass it to Openreach to carry out the repair.
Openreach normally aim to fix reported faults within 3-5 working days of being notified of them, but that could easily lengthen due to bad weather causing high demand, or if they have to get permission to dig up roads.
Avatar for jake+1507
Looks like I need a new micro filter,how do you order 1
@jake+1507  Would be quicker to order one online from that well known retailer.
You'll obtain a replacement more quickly by buying from an online retailer, such as here, or visiting a hardware store.
Locked
