Discussion topic: Is discovery plus in hd
This message was authored by NMF26 This message was authored by: NMF26
I just watched a repeat of an Olympic footie match and the picture quality was rubbish.
Locked
Re: Is discovery plus in hd
hi @NMF26,
I have watched a couple of things on catch up on the Discovery plus app.
I don't think it is quite SD but I would say it seems it can be quite variable and certainly not the normal HD we are used to
This message was authored by Outertrial This message was authored by: Outertrial
It's vile; I hate it. Compression artefacts and most feeds seem to be about 20fps.
This message was authored by fizzdisco This message was authored by: fizzdisco
It's better if you use a different Discovery+ app. The image quality on the Apple TV 4K box or Amazon Firestick 4K is better - sharper & less compressed than via Sky Q.
@fizzdisco I use a Firestick 4K & still don't find quality of the feeds that high  - even if it may be better than via SKY Q
This message was authored by bob1234 This message was authored by: bob1234
Like most I took the free trial but looking at the price for continuing with it and the content/quality I will not bother, I don't think it is worth an extra cost.
@NMF26 like most streaming apps Discovery+ uses a rate adaptive system so quality will vary depending on the speed of the network connection to your Q box . The Sky Q app is not listed as supporting UHD - the Apple TV and Firestick apps are apparently - but should offer HD quality but there maybe issues with server bandwidth as Discovery + is dealing with massively increased demand during the Olympics as Discovery hold the main European TV rights.
This message was authored by lettice This message was authored by: lettice
The olympic coverage on the Discovery+ is in HD. It is not the best HD I've ever seen, but it is HD and the pq is stable and consistent.
It is very watchable and not seen any problems with it.
As for other content, some is in HD and some SD.
That maybe more to do with the age of some of the content.
An example is to take a very early series episodes of Wheelers Dealers, that are shown in SD picture quality, but that has always been the case on many a Discovery owned channel previously on Sky satellite over the years.
But, look at a more recent series, like S16 and it is definitely HD and the quality via my Sky Q box is actually pretty good.
Much the same across the board from other series form what I have tried.
As mentioned above, the app does use adaptive bitrate streaming, so if you have a poor local network distribution or slow broadband connection speed it will cause some problems.
Sky Community Superuser. What is a Superuser? Click here to find out
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
Locked
