Discussion topic: Install for flats sky Q MDU
Message posted on 28 Jul 2021 10:42 AM
Hi I have an engineer coming out to install sky Q in a block of flats. I told sky I live in a block of 4 or more flats but someone said I should check the engineer coming does multi dwelling unit instillation. Is that right or will they just know that?
Many thanks
Message posted on 28 Jul 2021 12:03 PM
Re: Install for flats sky Q MDU
@MrJS91Sky "should" know from your post code / address if it is a communal dish and send the correct installer.
However you MUST get permission from the management agent etc for Sky to enter and make changes to the distribution system, and find out where the equipment cupboard is.
If you can't get permission Sky will not install Q.
