This discussion topic is read only Discussion topic: How can I add Sky sci-fi/horror non-hd channel?
This message was authored by: daves61
I've just added Sky Cinema but only get Sky Cinema Sci-fi/Horror in HD which takes up loads of space in the planner if I record a film. I cannot find the non-HD version  on my box - I think it should be channel 858 but it isn't there. Can I manually add the channel - if so what are the frequency details etc as I can't find those anywhere! Thanks
Locked
This message was authored by: Skyrobb3r5
Re: How can I add Sky sci-fi/horror non-hd channel?
 According to this
https://helpforum.sky.com/t5/Sky-Go-Apps/Sky-Cinema-SD-channels/td-p/3581168
there is no longer any Standard Definition channel.
Avatar for daves61
Thanks - yet on the TV guide it shows Terminator Dark fate as being on sci-fi/horror as well as the HD version.
It does show as being in SD but if you select it then it defaults to the HD channel.
@daves61 Yes, very strange. That channel doesn't appear to have a SD variant, but, as you say, if you Search for 'Terminator Dark Fate' it brings up showings on both HD and SD (even though SD doesn't exist.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Locked
