Discussion topic: Hardwiring a minibox which does not appear to have a n ethernet port
This message was authored by Pensionerandy This message was authored by: Pensionerandy
Can't find an ethernet port on minibox. Something that looks like an usb/c with a symbol like a musical treble clef. Do you use that with some sort of adaptor?
Pensionerandy
Locked
Re: Hardwiring a minibox which does not appear to have a n ethernet port
@Pensionerandy  All mini boxes should have an ethernet port.  It's the yellow one.
This message was authored by best+of+the+best This message was authored by: best+of+the+best
@Pensionerandy The ethernet port on the Sky Q mini may have a black rubber plug
which covers the port this is easily removed
@Pensionerandy
Note that the warning printed on the removable socket insert dates from 2016 and is thoroughly obsolete: the URL given no longer serves anything.
The socket you refer to is a standard USB 2.0 (A) that has no Sky functionality in domestic use.
Pensionerandy
Yes, thanks. Had a little rubber cover over it which was why I couldn't see it. Thanks!
Pensionerandy
Locked
