This discussion topic is read only Discussion topic: HDR programming stops being HDR durinf the programme
Locked
This message was authored by: Kei+M
Re: HDR programming stops being HDR durinf the programme
It's an issue we've only seen with LG TV's and we're working with them to find a solution but there's nothing included in QR17 aimed at this.
Thanks,
Kei
Community Manager
This message was authored by: darling412001
There is a post from @Kei stating Sky recognise it as a problem. And yes I am using the Sky HDMI lead.
Sky Stream
Sony A95K
Sony HT-A9
Hyperoptic FTTP 1.0Gbps
This message was authored by: fizzdisco
Thanks,
Interesting. Thanks for the update.
This message was authored by: jamo172
@Kei+M  I note your comments on this is only happening with LG Tvs however I have a Philips TV and I can assure you it is impossible to watch any HDR content as it loses the signal continuously.
This message was authored by: Darren+Talbot
This is an infuriating issue - yet another one with the V3 box.
Honestly if there was ANY other decent alternative I'd be out like a shot - I've been with SKY for decades and it's never been as disjointed or as unreliable as it is right now.
And the same box does it on 2 different TV's with have.
Infact as I type it's just turned itself off watching the football.  Samsung Q9FN.  No other source has EVER done it.
I'd even accept right now an option to just watch UHD without HDR until it's fixed but of course you can't do that...
hi @Darren+Talbot you can do that by setting the AV resolution to 2160 p 8 bit instead of 10 bit
This message was authored by: trevforum
You can, just set your audio visual setting to 2160p 8-bit.
Sky Stream, Sky Glass, Panasonic DX902, Pioneer LX-901 7.1.4
@Darren+Talbot you can by changing the settings  press  home down to settings then setup  then audio visual picture resolution sdelect 2160 and pick 8 bit rather than 10 bit
I never thought of that but.....
.... I really shouldn't have too....
This message was authored by: Tuckbox
Half time in the Everton v Burnley game. Happened 4 times so far.
And to get it back you end up missing parts to get it to re-engage!
Avatar for Paul+Furlong
This message was authored by: Paul+Furlong
Thanks @Kei+M for the update. As the original poster of this issue, it is disappointing that 9months on, we are still facing this issue of HDR dropping out, but appreciate the teams are working on it. It's definitely still happening. 😞
10 mins before tonights match and it's done it twice.
Did it within the first minute!!!
Well my box has updated to the latest software last night, since this has anyone reported the issue still happening?
Locked
