Discussion topic: Going from Ethernet back to WiFi connection
Message posted on 12 May 2022 09:01 PM
Hi. Long story short - my Sky Q box was installed in a downstairs bedroom due to the Sky engineer refusing to route it to my living room. Sky mini installed in living room. My broadband is Virgin hub 4.0 1Gb. Due to bedroom being a WiFi dead zone, I endured months of Sky dropouts in living room. So, I got a Sky engineer out. He still couldn't maintain a connection between the main and mini boxes. He ended up using LAN cables and boosters which worked. However, I was left with trailing cables around the house which not only look untidy but are a dangerous trip hazard. See diagram.
I invested in a Netgear WiFi extender and now have superb speeds in the bedroom where the main Q box is  So today I disconnected the boosters and cables and connected the main Sky Q and mini to my home network. BUT... the Sky dropouts started again despite my whole ground floor being swamped with excellent WiFi. The main box keeps losing connection despite being 8ft from my new wifi extender.
What am I doing wrong and can anyone help me resolve this issue?
Cheers.
Message posted on 20 May 2022 12:51 PM
@Dave+Hatton @oldfella @nigea99   SOLVED!  After trawling forums, trying your suggestions etc. I discovered this YouTube video https://www.youtube.com/watch?v=N7jA54B04YI.
So I put my VM hub into modem mode. I've used a spare NETGEAR WAC124 ac2000 router to connect to hub via Ethernet cable to get the router closer to the main Sky Q box (cable discreetly hidden so no trip hazard). Then connected a Sky booster directly to the router via Ethernet cable. Master reset the booster. When all 3 green lights were green, I connected main Sky Q and mini via WPS. All now connected to SKYXXXXX mesh. Been faultless for 24hrs now.
Hopefully this will help others that are being driven round the bend by Sky Q.
Cheers for your comments.
Message posted on 12 May 2022 09:04 PM - last edited: 12 May 2022 09:06 PM
							Re: Going from Ethernet back to WiFi connection
hi @Ian196 when your wifi is not SKY, SKY Q does not use your wifi for the minis but instead a wifi signal generated by the Q Main box
Message posted on 12 May 2022 09:05 PM
Hi @Ian196
Afraid Q boxes will not connect reliably to 3rd party WiFi units.
Where a 3rd party mesh system is used some success can be obtained by connecting the Q boxes to the WiFi units by Ethernet
Message posted on 12 May 2022 09:11 PM
Thanks @oldfella
I did connect the main Q to the extender via Ethernet thinking it would guarantee a connection but still dropped out.
Message posted on 12 May 2022 09:15 PM
@nigea99 But doesn't it use your home WiFi to 'carry' the signal to the minis?
Message posted on 12 May 2022 09:17 PM
@Ian196 wrote:
Thanks @oldfella
Hi @Ian196
Did you carry out a Network reset on the main Q box with the Ethernet connected
Try a Network Reset found in Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect wired and do not carry out any WPS.    If the connection is not made and held then it is not viable and connection must be made to your router
Message posted on 12 May 2022 09:18 PM - last edited: 12 May 2022 09:19 PM
Message posted on 12 May 2022 09:28 PM
@oldfella Hmmmmm. Not so sure I did. I'll try that tomorrow. If that works, how do I connect the minis? Via Ethernet cable to my WiFi hub (they sit next to each other).
Message posted on 12 May 2022 09:32 PM
Hi @Ian196
If you can get the main Q box working reliably then you can follow the same Network reset procedure on the minis with Ethernet connected.   Again do not carry out any WPS and wait for them to connect by Ethernet.
Message posted on 12 May 2022 09:42 PM
@nigea99 wrote:
@Ian196 wrote:@nigea99 But doesn't it use your home WiFi to 'carry' the signal to the minis?
No - it is a dedicated network generated by the Main Box which you cannot connect to (if you search for signals it shoud show as SKYxxxxxx )
@nigea99 Yeah I saw this but my main Q and mini were on different Skyxxxxxx networks
Message posted on 13 May 2022 04:26 PM
Hi @Ian196
Hi @oldfella   So I carried out your recommendations but the main box connected to SKYxxxxx and the mini to my home VM network.  So I tried again but this time main box connected to VM network, mini connected to a different SKYxxxxx network. Needless to say they were losing connection.
Any ideas? Do all boxes need to connect to either the same home network or SKYxxxxx network?
Message posted on 13 May 2022 04:36 PM
@Ian196 wrote:
Hi @Ian196
If you can get the main Q box working reliably then you can follow the same Network reset procedure on the minis with Ethernet connected. Again do not carry out any WPS and wait for them to connect by Ethernet.Hi @oldfella So I carried out your recommendations but the main box connected to SKYxxxxx and the mini to my home VM network. So I tried again but this time main box connected to VM network, mini connected to a different SKYxxxxx network. Needless to say they were losing connection.
Hi @Ian196
If you are using Ethernet connections then the Network SSID shown in your Qboxes status is irrelevant as this will refer to an historic Q mesh.
One further step that I should have mentioned was to turn off all WiFi in the Q boxes hidden menu immediately after the Network reset and successful connection.
Starting again with the main Q box exactly to what have you tried connecting the Ethernet.
Message posted on 13 May 2022 05:02 PM
@oldfella Thanks mate. It'll have to wait until next week now. Watch this space hahaha
Cheers
Message posted on 15 May 2022 09:32 AM
As others have said,  unless you are using SKY supplied wifi (which I have no experience of) the SKY Q and mini form their own seperate wifi mesh network, seperate from your home wifi.
Often this mesh competes/conflicts with your own wifi (in this case virgin?) setup causing a poor experience. Make sure both wifi networks  are on different wifi channels.
Now of course you are likely to need the SKY extender for the SKY mesh as you have already mentioned poor wifi in the bedroom.
Worse, for me, if you use your virgin powered wifi network only and plug the sky boxes in to this using ethernet cables, in my experience you may have random/regular failures because the network packets used in SKYs 'equipment discover process' (which runs continually to find out if there are any minis around)  can cause 'inteligent' equipment like mesh routers to crash/fail.
I personally have found that the best setup is to have a completely seperate wired (ethernet) with dumb/unmanaged switches connecting just the SKY equipment. On my broadband router, I seperate the traffic to/from sky using a VLAN.
I understand that this isn't convienient for most people but for me I get a pretty good experience with this setup.
Hope this helps.
Message posted on 16 May 2022 03:52 PM
@oldfella  @Dave+Hatton  @nigea99   Hi guys.  I have a Netgear EX7700 range extender next to my Main Q in the bedroom eradicating what once was a WiFi deadzone. This connects wirelessly to my VM hub 4.0 1Gb in the living room, giving me phenomenal WiFi speed.  I was hoping I could connect an Ethernet cable between the main Q and EX7700, thus effectively connecting 'directly' (kinda) to the VM hub 4.0 and then set up minis as per comments above.  Is this feasible?
Cheers
