Discussion topic: Disconnect from Sky Q, Sky Go no longer works
This message was authored by The+Real+ITSNev This message was authored by: The+Real+ITSNev
When using sky go on my iPhone IOS 15.1.1 with the option enabled for connection to Sky Q, the Sky Go app will stream live TV, eg Sky One, but as soon as I'm disconnected from Sky Q, the Sky Go app will not longer stream Sky One and give an error 17c.1.  The only channel that seems to work is 501 Sky News. I've spoken with Sky, and the don't seem to be able to help. I've removed my device from managed devices, remove the app, rebooted iPhone and reinstalled app, but same problem.  This is the first time I really need access to use the app to watch F1 today, as I'm not going to be at home.
When, I'm connected to Sky Q, on the same network, Sky Go works fine.
Locked
Re: Disconnect from Sky Q, Sky Go no longer works
Odd, have you tried installing the Sky Sports app as once logged in you should be able to watch the F1 via this.
The+Real+ITSNev
Unfortunately this does not work either. I sure Sky has messed up my account for this device.
I have escalated your post to Sky who will be in touch with you regarding this via a blue chat bubble which will appear at the bottom of this page.
This link explains how this works:
When the blue bubble does appear you have 48 hours to respond or it will be automatically closed.
This message was authored by Lisa-P1987 This message was authored by: Lisa-P1987
Posted by a Sky employee
Thank you for escalating this. We have now sent an invite to chat 🙂
Lisa - Sky Tech Team Expert
Update – We are still looking to help you. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks 🙂
The+Real+ITSNev
Yes please, still need support but I believe Sky has promised a call back tonight, so will update this thread with the progress, so if resolved other users will know what was done.
Locked
