Community help pages
Community Manager
Post 1 of 1
The Sky Community can help with a whole range of broadband issues, but to make things easier, we’ve created some articles which should point you in the right direction.
Help with Sky Broadband
These steps will help diagnose what may be causing your Sky Hub to lose connection or receive slower-than-expected speeds.
Sky Hub settings page
Your Sky Hub settings page enables you to configure your home network to suit your needs
Set a Wi-Fi timer
Want to keep the kids off the Wi-Fi at certain times? This will help.
Change your wireless channel
If you'd prefer to manually set a Wi-Fi channel, follow these steps.
Sky.com/help can help you with your Sky Broadband questions
Change your Wi-Fi password
Your default password is printed on your Sky Hub. If you'd like to change it follow the link.
Constant amber internet light
If your Sky Hub is struggling to establish an internet connection, this article should help.
Intermittent broadband connection
If you're losing connection, check out these steps.
If you haven’t found the help you’re looking for, post your question on our broadband community.
Mark
Community Manager
