This discussion topic is read only Discussion topic: Can’t connect sky+ HD box to broadband router. So no catch up tv/on Demand
This message was authored by: Florence29
I've tried all online help from sky to connect to my I can't use an Ethernet cable as it won't reach. Tried WPS button Idea but don't have one on my SKY+HD BOX. Suggested ordering a Sky Demand connector from Sky but no longer available.
Any ideas?.
Thank you in advice
Locked
Re: Can’t connect sky+ HD box to broadband router. So no catch up tv/on Demand
Any ideas?.
Thank you in advice
Hi @Florence29
I will move you post to the correct Sky+forum
@Florence29 there are several options. The simplest is probably to look for a second hand On Demand Connector. There are usually a few for sale on ebay.
<snip>
Your sky box is over 100m from your router?
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Locked
