2
This discussion topic is read only This discussion topic has been answered Discussion topic: Can't connect Sky Q remote to Q Acoustics M4 soundbar
This message was authored by: SarahS
I can't control my Q Acoustics M4 soundbar with my Sky Q remote control. There appears to be no code available and it won't connect automatically when I try connecting it using the 'Remote Control setup' functions in the Sky menu.
The soundbar is connected to the Samsung TV via Optical cable.
Can someone advise if  I can resolve this problem? I no longer have the small Q Acoustics remote.
This message was authored by: LGUser Answer
Re: Can't connect Sky Q remote to Q Acoustics M4 soundbar
Yes you can. This link takes you to the answer on Q Acoustics website.
https://desk.zoho.com/portal/armourhomeelectronics/en/kb/articles/sky-q-handset-won-t-operate-speake...
Locked
Avatar for SarahS
Thank you so much!. That worked perfectly and it was indeed setting 7 under Philips that worked.
Locked
