Discussion topic: CAT 6 ethernet to Garden room
Message posted on 21 Oct 2021 05:08 PM
Hi I have just had a cat6 Internet cable fro. Garden room into the main house. Can I just plug ethernet cable from main router to box in main house and from box in Garden room into ethernet port on minibox? Thanks for any help
Message posted on 21 Oct 2021 05:26 PM
Re: CAT 6 ethernet to Garden room
hi @Scotty197108 I think it depends on whether your router is SKy or not.
If you are with SKy then I think yes.
If you are with another provider then you can connect the mini to the Main box or both the mini & Main into the router (or other unmanaged switch)
Message posted on 21 Oct 2021 05:29 PM
Thanks for reply yes I have Sky router tried it earlier but didn't have any success was just stuck on screen which says connect to WiFi or use ethernet...!
