Discussion topic: Credit redund and return the Sky Max Hub
Message posted on 26 Sep 2025 02:55 PM
I have credit in my Sky account, and I would like to request a refund back to my bank account. Additionally, I would like to obtain the packaging for returning the Sky Max Hub.
Message posted on 26 Sep 2025 03:02 PM
Re: Credit redund and return the Sky Max Hub
Refunds normally take about six weeks from the last day of connection but posts on here suggest it's taking longer.
We could normally escalate this to Sky on here via their Messaging Team but unfortunately the process is currently switched off and we don't know when it'll return.
At present you will need to contact Sky and speak to an agent by other means; through social media, Sky Assistant or by calling in perhaps. Providing your payment method is still active they should be able to refund it in 3-5 WORKING days.
If you’ve successfully cancelled Sky should send out returns packaging (to the address where the account was active) near the end of any cancellation period (which is 14 days for broadband and 31 days for Sky Q) for any loaned equipment they are expecting back.
Note: Sky may not ask for older hubs back such as the Sky Q hub.
If the arrival of packaging is delayed, it’s damaged on arrival or doesn’t arrive it’s the customers responsibility to use their own packaging to return it. You can use any packaging as long as it’s secure and you may want to put a note inside with your account number and a list of equipment that is included. This link explains about how to receive an email with your return labels through Royal Mail.
https://www.sky.com/help/articles/return-tv-broadband
Keep your proof of posting safe and indefinitely and if you use Royal Mail’s collect from home service, keep a record of the tracking number.
Message posted on 26 Sep 2025 03:26 PM
Thanks for your answer. Much appreciated!
Which number is the best to contact an agent about the refund and Hub return problem?
Message posted on 26 Sep 2025 03:28 PM
You don't have a problem returning the hub that I can see. My reply explains what to do.
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers. Other official numbers to Sky from the UK are 03 numbers which are normally inclusive from non Sky phones.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
🟩 online help via this link
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note ~ ROI customers 🔹If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
