Help
Help
Answer
Occasional Visitor
charlie401
Accepted Solution
i have a bush bled32hdrae tv. the sky remote will not work on the sound button.
Hi just bought a Bush 32 inch HD LED TV, model BLED32HDRAE. The SKY remote will not work adjusting the volume. Ive tried resetting the code using the "999"method. Ive also tried the "select and red button together" method but neither have worked. I love my new TV, but hate that the Sky remote wont work!! Any more ideas anyone?! Lesley
Accepted Solution
Staff (Retired)
GRF4784
Answered
Hi charlie401,
Thank you for posting your question.
If you follow this link it will allow you to check if a code is available for your TV.
If this has helped you please mark this post as an Accepted Solution.
Many Thanks,
Other Answers: 2
Regular Visitor
nads.1978
Answered
2267 is the code for Bush bled32hdrae probably need a Rev9 Sky remote
Occasional Visitor
marshy22
Answered
I have a bush LED32w tv and can't get the sky remote programmed, any suggestions for a code
