Help
Help
Answer
Frequent Contributor
skystan
Accepted Solution
My Sky box is running really slow
It takes ages for the box sometimes to respond to the remote control and when it does it'll usually jump a few steps at a time, is there anything I can do?
Retired Staff Member
GRF4784
Answered
[ Edited ]
Hi Skystan,
Thank you for posting your question.
Can you put the box in to Standby mode>Switch off at the mains for 5 minutes>Switch back on>Leave in Standby mode for a further 5 minutes and see if this has helped.
If you have a Sky+ or Sky+HD box you could also try a Planner Rebuild.
Many Thanks,
Other Answers: 3
Occasional Visitor
Eds1
Answered
My sky box is run slow when us it, from the time sky sent up date to my in November 2012?
Occasional Visitor
Iurwin
Answered
When navigating sky tv menu the response is very slow
Occasional Visitor
neil+c+smith
Answered
The planner rebuid worked for me.  I have had to do it a couple of times to sort out problems with the planner but this is the first time I have used it for response times - how long the effect lasts though I'm not sure!
