Help
Help
Answer
Visitor
SkyKen
Accepted Solution
Sky box broken, can I use my card in another box?
As above. I have a Sky+ box that is not working and have a chance to get a Sky+HD box from a friend. Will my curent card work in this box ( i'm not interested in HD)?
Accepted Solution
Super User
caesarome
Answered
Yes it will do but you will need to call Sky to get them to pair the card to your replacement box.
__________________________________________________________________________________________.
I do not work for Sky.
Other Answers: 1
Staff (Retired)
Jileen
Answered
Good Morning SkyKen,
If you are using another box, you will need to pair your card. You can do so in here:
www.sky.com/wrongcard
Thanks!
