Showing results for
Search instead for
Do you mean
Help
Help
Answer
Occasional Visitor
carly192
sky hd box green light on but no picture
My sky hd box had a fault and I was unable to view listings, record programmes or view my recorded programmes, after reading the sky help section it told me I had to do a planner rebuild, I followed all the instructions but now the light on the box is green but there is no picture at all??? I then tried the turning off the power holding the back up button etc about 5 times but still nothing, please help???
Other Answers: 2
Super User
caesarome
Answered
When turning off and then holding down the backup buttopn on the box you need to then turn the box back on but keep that button held down until you see the on screen message.
__________________________________________________________________________________________.
I do not work for Sky.
Retired Staff Member
Joss-91
Answered
Hi carly92,
Can I check if everything is now sorted?
Let us know if you need any further help.
Thanks,
