Showing results for
Search instead for
Do you mean
Help
Help
Answer
Occasional Visitor
correspondent
how do i transfer recordings from my Sky HD box to a DVD recorder?
My HD manual does not show how to transfer recordings from my HD box to a DVD recorder.  Can you please advise the procedure for doing this?
Other Answers: 1
Super User
Mark39
Answered
Connect the Sky box to your DVDR by SCART cable.
On your TV, select the input that the DVDR is connected to.
On your DVDR, select the SCART input and turn your Sky box to the Planner. If everything is connected correctly you should see the Planner on your TV.
Prepare your DVDR for recording
In the Planner select the recording you want to copy and press play on your Sky box.
On your DVDR press record.
