Showing results for
Search instead for
Do you mean
Help
Help
Answer
Visitor
SkyKen
Accepted Solution
Sky box broken, can I use my card in another box?
As above. I have a Sky+ box that is not working and have a chance to get a Sky+HD box from a friend. Will my curent card work in this box ( i'm not interested in HD)?
Super User
caesarome
Answered
Yes it will do but you will need to call Sky to get them to pair the card to your replacement box.
__________________________________________________________________________________________.
I do not work for Sky.
Other Answers: 1
Retired Staff Member
Jileen
Answered
Good Morning SkyKen,
If you are using another box, you will need to pair your card. You can do so in here:
www.sky.com/wrongcard
Thanks!
