Booster box won’t connect
Answered
Go to Answer
Runner
Post 1 of 12
Booster worked fine before recent holiday. Came back, not working. Turned white booster box off, then on again. All 3 lights go green. When the on-tv setup command says ‘press nearest product button’  I press booster button to flash yellow. The booster ‘connected’ light immediately goes off. Minibox doesn’t connect. The Yellow flashing light on booster box eventually goes off and the green booster ‘connected’ light comes straight back on!? (Main box in main room, everything ticked on screen.) Any ideas would help with World Cup starting & two tvs needed, lol.
Answer
Answer
Editor
Post 4 of 12
Re: Booster box won’t connect
Try the following- reboot your internet hub followed by your skyQ main box then your booster, and finally the mini leave for a few minutes to allow the system to stablise
Editor
Post 2 of 12
Try the following- Reboot your internet hub, then your SKYQ main box, then your booster followed by your Mini box, wait a few minutes for the system to connect.
First Assistant Director
Post 3 of 12
When you have pressed the WPS button on the booster you have to press the WPS button on the mini as well.
You could try resetting the network connection in the settings on mini if this doesn’t work
BT Ultra Infinity. Apple Time Capsule. Sky Q 2TB watching UHD through a LG OLED55B7 and listening through a soundbox. Multiroom with 2 miniboxes
Answer
Editor
Post 4 of 12
Runner
Post 5 of 12
Thanks! Will do.
Production Supervisor
Post 6 of 12
Pretty sure that's not true. The mini automatically puts itself into WPS mode when it asks you to press the WPS button on the nearest box.
Runner
Post 7 of 12
Pushing buttons on both boxes didn’t work, same sequence. Will try network reset.
Runner
Post 8 of 12
Yes, I think so.
Runner
Post 9 of 12
I turned everything off & everything back on again. Was hopeful! Got a green rather than red flash on main box & all lights on on booster. But Computer said NO. Again...
BUT as you suggested, although it said it couldn’t connect the system must have stabilised coz it suddenly got further thru sequence. Hurrah!! 10 mins later it’s fully working after 5 mins of on/off.
Thanks so much.
Post 10 of 12
@EsherMac
Well done.
Editor
Post 11 of 12
Thanks so much.
Glad it is now all as it should be Smiley Happy
Post 12 of 12
Yes you are right 👍
Recommended Threads
16-04-2018 04:20 AM
18-05-2018 10:05 AM
4 weeks ago 10:49 PM
16-04-2018 12:09 PM
3 weeks ago 12:32 PM
