No network connection
Runner
Post 1 of 9
Can someone advise why I don't receive or can't send emails away from home.  In spite of having a mobile phone signal I get 'No network connection. No signal found for mobile networks' when I try!
Oracle
Post 2 of 9
Re: No network connection
Hi @IWRA
Try turning on Airplane mode and then turn it back off again.
Also check your network settings mode - Go to settings – more options under wireless and networks – mobile network – network mode. Try to choose GSM/WCDMA/LTE (autoconnect). Once you have chosen this option try to check if you still get the same error message.
If the error still occurs try setting up the APN settings:
Settings > Mobile Data > Create New Access Point...
Name: Sky Mobile Internet
APN: mobile.sky
Save and restart phone.
__________________________________________________________________________________________.
I do not work for Sky.
Runner
Post 3 of 9
Many thanks for your advice, however no luck so far I'm afraid.  The phone is a Samsung S5.  I was with Virgin where I had no issues.  The network operator on Mobile Networks is 'Sky' and the Mode is 'LTE/3G/2G (auto connect)'.  Mobile data and data roaming are both selected.
Networks available via Network Operators are Sky,  Vodaphone Uk, EE & 3 UK.  VPN returns 8 options including PPTP and asks for a server address?
The phone states 'Access point name settings are not available for this user'!
Oracle
Post 4 of 9
Try disabling the mobile data connection and connet to your Wifi network instead and also reboot your phone.
Runner
Post 5 of 9
No change I'm afraid
Camera Assistant
Post 6 of 9
Check you DO NOT have mobile data switched off.
Runner
Post 7 of 9
I have the mobile data box ticked
New Viewer
Post 8 of 9
I have exactly the same problem today. I have tried everything and nothing works. Please help
Runner
Post 9 of 9
I rang the Sky help line and we changed the settings on the phone, it's working fine now
Recommended Threads
a month ago 01:09 PM
a week ago 06:50 PM
22-03-2018 07:09 PM
a week ago 02:34 PM
19-03-2018 10:59 PM
