Help & Support
New Member
suzanne1
sky hd+ box
Hi everyone , new on here :smileyhappy:
Needing a bit of advice , I bought a second hand sky hd+ box and have connected it to the dish via a 2 way lnb , so I have both cables into box , I have a basic sky subscription and so I have placed my sky card into the new ( 2ndhand) box , and everything works perfect except I can't get the sky+ to work ! Do I have to subscribe to this or is it a freebie ? when i look on the internet all it tells me is about buying a new box with hd and sky+ !!!
Also there was no manual with the box so im not 100% sure if it is the same workings ie:auto view & series link as the old boxes ? would really appreciate the advice
Million thanks guys :smileywink:
Senior Member (Platinum)
Mark39
Re: sky hd+ box
Hi Suzanne,
First thing to do is to call Sky and 'pair' your Viewing Card with your new Sky box. If Sky+ forms part of your basic subscription, that should sort it out.
I doubt your new box has autoview - that went a long time ago, though you can make it remind you when a particular programme is about to be shown. Series link is still the same.
What make and model is your new box? There are manuals for the Sky+HD boxes online.
New Member
suzanne1
Re: sky hd+ box
thanks , i have contacted sky and i think we may be ok , ive added sky+ and paired the box to the card , so now im just waiting for it to activate , they sai 2mins to 4hrs and that was about an hour ago so im still waiting :smileyhappy:
Thanks again
Sky Knowledge Advisor
GarryC
Re: sky hd+ box
Hi suzanne1,
Did your channels activate within the 4 hour period?  Is everything ok now?
Thanks,
Garry
Forum Help http://helpforum.sky.com/t5/help/faqpage
Sky Help Centre http://www.sky.com/help
New to the forum? Click here
Tagging your posts and others with relevant key words is another way to help,
it also counts towards forum rank.
  1. © 2012 BSkyB
  2. Terms & Conditions
  3. Privacy Statement
  4. Security Centre
  5. Accessibility Information
  6. How to complain
