Help
Help
Sky+HD, SkyHD & Sky 3D
Occasional Visitor
tigersfoot
Accepted Solution
tv guide slow to respond or doesn't respond at all.
Hi please help as this is driving me up the wall.  Though I can get up the main tv guide page it either doesn't respond any further or is very slow to respond to commands.  I have tried resetting the box by turning the power off at the wall for several minutes and starting it up again but this doesn't make any difference.  Any ideas?
Stay Safe: Don't post any personal details or Sky account information. Plain text only in this box.
Senior Member
Pete+H2K
Re: tv guide slow to respond or doesn't respond at all.
Hi,
you can try a planner rebuild, this may help in this situation.
1. press services 0 0 1 select
2. Press right to rebuild (will expand to Sky+ rebuld)
3. press select twice. after about a minute or two, the box will turn off and go in to standby.
4. wait 3-4 minutes and turn on.
Cheers
Pete
_______________________________________________
this post contain my own views and suggestions based on past experiance.
I an not affiliated with Sky in any way.
Equipment: Thomson HD 4E3007 box, xBox, Sky BB, Sky Talk
If this post has helped you, you can thank me by clicking the pink star to give me Kudos :-)
Occasional Visitor
bobbybee
I too have noticed in the last few days that there can be several seconds (up to possibly 10) before the sky box reacts to the keys pressed on the handset
Occasional Visitor
jungle-expert
The solution posted helped me solve the problem . Thanks!
Occasional Visitor
yamilad
i have been very frustrated with this for weeks, press the bottons, nothing hapens for up to 10 secs, press more buttons, then i dont know whats happening, arrrgghh.
Performed the task above and hey presto......
Why did i wait so long....????
Retired Staff Member
GarryC
Hi Everyone,
It is great to see that the suggestion of a 'planner rebuild' made by Pete+H2k is resolving your issue and thanks for taking the time to let us know how you are getting on once you try it.
Occasional Visitor
Lesh73
Do you know why this happens in the first place?
GarryC
Hi Lesh73,
As your Sky box has a hard drive installed in it, it works a little like a computer and can become slow to respond.  The planner rebuild is a process which tidies the files in the hard drive up and helps it run as normal again.
Thanks,
Occasional Visitor
liz.b
Before I do this, could you confirm I won't lose my recording in my planner? Thanks :smileyhappy:
Super User
kato
You will not lose any of your recordings while carrying out a planner rebuild.:smileyhappy:
___________________________________________________________________________________________
If you have been helped by someone please click on the thumbs up icon to give them Likes.
Occasional Visitor
Gavin+Cork
Tried the fix this morning, my HD box now running smoothly again
Many thanks
Gav.
Occasional Visitor
kingsway123
if i reset the box as suggested - will i lose the programmes recorded in the planner
Super User
Mark39
See the post 2 above yours.
Occasional Visitor
Patrick+Mullins
You're a genius. Should be working for Sky. Worked a treat.
Occasional Visitor
PBW1959
Many thanks for the solution originally posted. It worked for me and removed an irritating niggle.
Thanks again.
Paul.
Pete+H2K wrote:
Hi,
Cheers
Pete
Many thanks Pete, it worked for me and resolved an irritating niggle.
Thanks again.
Paul.
