Help & Support
New Member
carlab
Accepted Solution
Re: sky+ playback and recording unavailabl​e.
Hi, I was wondering if anyone can help me. I have the following fault coming up when I try to pause live tv or record. System fault - sky+ playback and recording unavailable. I have tried a system rebuild and a full system reboot but its still not working. any ideas?? I also have nothing showing in my planner and didnt have before i tried the rebuild/reboot and also in anytime.
Senior Member (Platinum)
Mark39
Have you recently upgraded, or has this fault suddenly appeared on a box you've had for a while?
New Member
carlab
its only just happened. had the box for just over a year and a week past the warranty it packs in. spoke to sky tonight who have now totally buggered up the whole thing so i have no signal at all. So no tv whatsoever until they can come on sunday to fix it! not hapy at all. at least i could watch something before speaking to them and had satalite signal now for some reason its totally gone and is no longer receiving any signal.
Mark39
Sorry to hear that. You could try a full system reset (as opposed to a reboot which you've already tried) as a last try, though you'll lose any recordings on the planner: http://www.sky.com/helpcentre/tv/sky-plus-hd/recording/performing-a-full-system-reset/index.html
If that doesn't help - be prepared for a box swap on Sunday.
Kenneth+M
carlab wrote:
............had satalite signal now for some reason its totally gone and is no longer receiving any signal........
Check your two Dish Input connections.  Make sure that both cable connectors have around 3mm of centre core to make a good connection, and that they are properly screwed into the Dish Input sockets.  Also check the Service Menu ( Services, 0, 0, 1, Select ).  In 'Setup' there, make sure LNB Power Supply and 22KHz Command are both switched ON.  If not, change to ON, then press green to Save Settings.
New Member
jake210
My box is recording but live pause and rewind wont work the blue light is on but wont rewind or pause
caesarome
Try a planner rebuild:
http://www.sky.com/helpcentre/tv/sky-plus-hd/recording/guide-to-performing-a-planner-rebuild/
__________________________________________________________________________________________.
If someone has helped you then please click on the thumbs up icon next to the reply button to give them Kudos
  1. © 2012 BSkyB
  2. Terms & Conditions
  3. Privacy Statement
  4. Security Centre
  5. Accessibility Information
  6. How to complain
