Help & Support
A.I
New Member
A.I
Broadband Connection Speed : Slow
Hi,
I've been promised 20mbp internet speeds and pay for the service.
However we have done several speed checks and discovered that we are recieving internet speeds as low as 0.07 mbp which is by anyones standard disgracefully low.
We have done tests at the following times on 9th July 2011
12:15am - dwnload speed : 0.188 mbp upload : 0.665 mbp
12:16am - dwnload speed:  0.707 mbp upload : 0.670 mbp
12:17am - dwnload speed: 0.343 mbp  upload : 0.670 mbp
12:18am - dwnload speed: 0.429 mbp upload : 0.673 mbp
12:20am - dwnload speed: 0.480 mbp upload : 0.669 mbp
These are the exact times at which they where taken. These times are the times where internet traffic is at its lowest and the speed was lowest too. These are unnaceptable speeds at prices that are worth the promised 20mbp. We would like to hear from you soon and a solution to this problem asap otherwise i have no choice but to switch network as internet is too slow for the work and usage needed in my household.
Thank You
Ariff Idris
Sky Knowledge Advisor
Robert
Re: Broadband Connection Speed : Slow
Hi Ariff,
In order to assist with this issue can you provide the following information relating to your set-up?
  • Where your router is connected to your line, is it in the master socket or on an extension socket / cable?
  • Do all phone sockets on your line have a microfilter connected?
  • Have you tried our Slow Connection Troubleshooting Guide on the Help Centre to ensure correct setup?
Can you also provide the following stats from your rotuer:
  1. Log in to the router by going to http://192.168.0.1
  2. When prompted enter the username: admin & password: sky (in lower case)
  3. Scroll down and click on the Show Statistics button
  4. Copy & Paste the contents of the window that opens up into a reply to this post a long with the information requested above.
Robert
Forum Help http://helpforum.sky.com/t5/help/faqpage
Sky Help Centre http://www.sky.com/help
New to the forum? Click here
Tagging your posts and others with relevant key words is another way to help,
it also counts towards forum rank.
Member
BRIT+KAYAN
Hi..it seem my speed connection going down again. Can some check it for me why it keep droping once it pick up speed for a few weeks.
Here are the stat:
 ADSL
   TypeInterleave Path
   StatusShow Time
   DownstreamUpstream
   Data Rate (kbps)512414
   Noise Margin (dB)15.016.0
   Attenuation (dB)48.729.2
   Output power(dbm)13.26.7
Robert
Hi BRIT+KAYAN,
I understand your frustration, if your line speed is constantly dropping it usually indicates a problem with set-up, this can be caused by a number of things from a faulty microfilter to devices being connected to your line which are not filtered correctly.
Can you tell us where your router is currently connected, is it connected to the master socket or an extension?
If you have a test socket (see picture below) can you try connecting the router directly to this using a microfilter and removing all other devices from the line, once you've done this please post another set of stats from the router so that we can compare the line conditions.
Thanks,
Robert
Member
GersMan007
Stop blaming the people fix the broadband sky
 you blame everything its them to blame so stop and fix the exchanges and crap copper lines
get fiberoptic everywhere
Member
GersMan007
That's to only way we wil get 20 meg above post
New Member
Pudding889
My Network Type has suddenly changed to MER and my speeds are extremely slow. Whats going on?
Member
GersMan007
puddin am mer as well and slow as well whats going on
New Member
Pudding889
I'm not sure to be honest but from reading about apparently peoples Network Types changed to MER when Sky were moving servers earlier in the year. Don't know if Sky are doing maintenance again.
Member
GersMan007
They should tell us  when they are doing maintenance
the only advice you get is plug in to main phone socket
I have rebooted my router stuck a pen in it
still crap speed why that please help
Member
GersMan007
what the hell is MER and kernel: Line 0: xDSL G.994 training?
Member
GersMan007
DownStream Connection Speed UpStream Connection Speed
1394
606
slow speed why ?
Member
GersMan007
Me thinking slowing payment to sky like there slow broadband
mibie they will fix it
Member
GersMan007
Today speed
Line Attenuation Noise Margin
1535 kbps606 kbps
61.5db38.4db
6.1db12.7db
Member
GersMan007
Done a speed test = 1.3Mb
 another test
Today 15:211344 kbps (168kB/s)499 kbps (62.4kB/s)
  1. © 2012 BSkyB
  2. Terms & Conditions
  3. Privacy Statement
  4. Security Centre
  5. Accessibility Information
  6. How to complain
