wireless password
Answered
Go to Answer
New Viewer
Post 1 of 46
wireless password
I have forgotten my password for my sky wireless how can i find out what it is?
Answer
Answer
Staff
Post 5 of 46
Re: wireless password
Hi keer, the wireless network password/key is written on the sticker underneath the router.
Malcolm-M
Oracle
Post 2 of 46
You mean to login to the router. If so it could be:
Username - Admin
Password - Sky
__________________________________________________________________________________________.
I do not work for Sky.
Retired Staff Member
Post 3 of 46
it's written on the bottom of the router, isn't it?
Sorry not looked in ages
New Viewer
Post 4 of 46
hi dear i have lost my password for internet
Answer
Staff
Post 5 of 46
Malcolm-M
New Viewer
Post 6 of 46
I am trying to sign in to the router but require my wireless password, I have tried entering the network key but this comes up as incorrect password
Runner
Post 7 of 46
I have just purchased a tablet PC and it says it needs my WPA password to connect. How do i get this??
HELP!!!
Runner
Post 8 of 46
This does not solve the problem I have entered that to try and get a kindle running but it does not accept this as password
So come on sky what is the solution
Oracle
Post 9 of 46
HELP!!!
It is on the bottom of the router.
Oracle
Post 10 of 46
What have you tried, the password on the bottom of your router or somethintg else ?
Oracle
Post 11 of 46
To sign into the router use:
Username - Admin
Password - Sky
Runner
Post 12 of 46
I have also been trying to put the password on the router onto my kindle, but  but it keeps telling me that it's incorrect.  someone please help!!!
Runner
Post 13 of 46
Sory to hijack but i'm having same problem.
I have tried the admin/sky to access my router but i'm getting incorrect password displayed. Is it possibe I could have changed the password at some point?
Oracle
Post 14 of 46
It is possible you have changed it, there is a small hole on the router which you would need to use a pen or something to press it to reset it back to the original password.
Staff
Post 15 of 46
Hi Guys, the Kindle can be connected to your wireless router using the network key printed on the keep me handy card and the sticker on your router. I have been advised that there is no caps-lock function so you need to press the shift key before each character you enter to ensure it is in uppercase.
Recommended Threads
