Sky wireless booster - Manual setup - Browser setup page not loading
Answered
Go to Answer
Researcher
Post 1 of 16
I have just received my wireless booster.  My sky router does not have WPS so trying the manual setup.  All equipment connected correctly but the setup page will not load on my internet browser, just says page loading but it doesn't.  Please help.
Booster is now working!  Problem resolved by following a solution left by username "steven+elmes".
Follow manual setup instructions and wait for the browser setup page to say loading for ages. Stick a pin in the reset point on the back of the booster.  Wait for the lights on the front to flash and remove pin. When lights stay on permanent white try reloading page.
Answer
Answer
Executive Producer
Post 2 of 16
Hi try the link below. use 192.168.0.1 and user name admi...
Hi try the link below. use 192.168.0.1 and user name admin password sky. Thanks Sean
http://help.sky.com/broadband/set-up-sky-broadband/set-up-your-sky-wireless-booster#!connect-manuall...
Answer
Executive Producer
Post 2 of 16
Viewer
Post 3 of 16
i tried for ages to connect but no luck.  then i happened...
i tried for ages to connect but no luck.  then i happened to look on my iphone and found the sky booster in the wi-fi settings .i connected to it rather than my router and was able to enter my router details and within seconds the booster is up and running!
New Viewer
Post 4 of 16
I cant connect to the site skywirelessbooster.local , I a...
I cant connect to the site skywirelessbooster.local , I am using Safari on an imac.
please help
Viewer
Post 5 of 16
I try to go on skywirelessbooster.local and I click enter...
I try to go on skywirelessbooster.local and I click enter but Quick setup did not appear. therefor I can not go further. I haveSSID
and Net work key on my Sky Broadband router.Please let me know how I can further to boost my signal
Runner
Post 6 of 16
Hi all, I couldn't get the wireless booster set up manual...
Hi all,
I couldn't get the wireless booster set up manually because ai kept getting as far as the local page and then the address in the addressbar kept adding an extra login command so taking me to a login page. None of my passwords would work so I called sky and the guy sussed it:- for login password type    sky   that's it. I'm now up and running. hope this does the job .
New Viewer
Post 7 of 16
i have a bt hub router and it wont connect to sky box eve...
i have a bt hub router and it wont connect to sky box eventhough it works
i need it to be able to watch catch up and on demand
please help
Executive Producer
Post 8 of 16
see this     @fifi+hunt how have you tried to connect? wi...
 see this
@fifi+hunt how have you tried to connect? wifi or cable?
Runner
Post 9 of 16
Can't open quick set up page
Staff
Post 10 of 16
Hey @kaparelli8 ,   Can you let us know exactly what you...
Hey @kaparelli8 ,
Can you let us know exactly what you are trying to do or what you need assistance with and I can certainly help?
Please get back to me when you can.
Series Linker
Post 11 of 16
Re: i tried for ages to connect but no luck.  then i happened...
This worked for me too, many thanks,
Viewer
Post 12 of 16
Re: Sky wireless booster - Manual setup - Browser setup page not loading
Hi,
A few days ago i received my wireless booster.. It was connected and i had exellent signal on new connection named "sky booster".. But yesterday my brother did something and now that new connection named "Sky-Booster" has just disappeared, any solutions what to do next?
Runner
Post 13 of 16
this worked for me Smiley Happy thank you <3
Runner
Post 14 of 16
What's the password really struggling?
Runner
Post 15 of 16
Visit Skywirelessbooster.local and it comes up with a Login Page
What's the password?
