on ‎09-08-2011 06:38 PM
I have a similar issue with slow connections. When I had the same BT line with a broadband service from O2 my connection speed was roughly 3Mbps now with sky its roughley 1.5Mbps.
My connection stats are (from the master socket):
System Up Time: 323:01:48
| MER | 274417 | 7938020 | 0 | 38827496 | 2147483647 | 56:57:17 |
| Up | 6507151 | 3809856 | 0 | 150132760 | 354968428 | 323:01:48 |
| Up | 2456705 | 1649347 | 0 | 2147483647 | 207761274 | 323:01:29 |
| 1535 kbps | 604 kbps |
| 64.0 dB | 38.4 dB |
| 9.0 dB | 12.6 dB |
What do I need to get sky to alter my noise margin.
on ‎11-08-2011 10:38 AM
I usually get 107KB/ sec or below but aren't I entilted to get above that? like 200KB?
How can I improve my speed?
on ‎21-08-2011 11:36 AM
Hi.
I moved house recently and where i used to get a 1MB/s download rate it has slowed by 40% to 600kb/s.
Am wondering why this is the case? I have the same set up as before.
System Up Time: 44:08:59
| PPPoA | 1628626 | 2215749 | 0 | 38550 | 0 | 44:07:57 |
| 15 | 0 | 0 | 0 | 0 | 44:08:59 | |
| 2283785 | 1704979 | 0 | 0 | 46880 | 0:09:20 |
| 6141 kbps | 796 kbps |
| 39.5 db | 21.1 db |
| 6.3 db | 11.5 db |
| Poll Interval: (secs) |
Am wondering if you could shed some light on this.
Thanks.
Dave
on ‎31-08-2011 11:56 PM
‎01-09-2011 08:39 AM - edited ‎01-09-2011 08:42 AM
After reading more of the forums I've completed the Sky Troubleshooting steps, (checking microfilters, etc), and plugged my router into the BT Test socket but nothing has improved really:
http://www.speedtest.net/result/1460393344.png
ADSL Link Downstream UpstreamConnection SpeedLine AttenuationNoise Margin
| 761 kbps | 561 kbps |
| 62.5 dB | 38.1 dB |
| 10.1 dB | 11.5 dB |
on ‎18-09-2011 07:45 PM
Router Statistics
System Up Time: 00:21:03
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up TimeWANLANWLAN
| PPPoA | 28047 | 32640 | 0 | 2573 | 31141 | 00:20:23 |
| 15265 | 13788 | 0 | 11803 | 1875 | 00:21:03 | |
| 19123 | 15466 | 0 | 20467 | 1207 | 00:20:15 |
| 896 kbps | 448 kbps |
| 53.5db | 31.5db |
| 8.3db | 16.0db |
 I have just made a copy of my broadband statistis and as you can see it's very very slow. I have had my installation checked twice and all materiels, cables, PC and software are very recent - Windows 7 64bits - up to date and are working perfectly fine. The ADSL filter has been changed for a new one. So now my question : it's still not working fine with several interruption at peak time. I do not download music of files or pic. I am just browsing the internet and checking my email. What not just saying that I can only be provided with cr-- because I am living nearby a town but not in a town.
thanks for the info
on ‎20-09-2011 11:26 AM
Hi cocochinois, what estimated access line speed (EALS) did sales or our web site advise your line should support?
If you are having problems with your speed please try the troubleshooting here. If this does not help I would advise trying your router in your test socket if you have one, or in the master socket on it's own if you don't, with a different filter and posting the router statistics you see there along with the statistics from your current configuration.
If you have a horizontal split across your master socket as shown in the picture just above the microfilter then you should have a test socket. Remove anything you have plugged in to the socket then undo the two screws and gently remove the bottom half of the faceplate (it may have wires attached to the back). You should then see the test socket in the bottom right corner. If the faceplate is one piece of plastic then you don't have a test socket so don't attempt this.
To get the full router statistics go to http://192.168.0.1 then log in with admin and sky and click on show statistics.
![]() | New to the forum? Click here | |
| Tagging your posts and others with relevant key words is another way to help, it also counts towards forum rank. | ![]() ![]() | |
on ‎20-09-2011 11:36 PM
Hi I also have a poor connection,im on the unlimited broadband package,I have changed my microfilters,my router is plugged into the master socket,ive done the trouble shooting but still have a poor connection.Here are my stats if someone could have a look please,thanks
| PPPoA | 24754 | 37524 | 0 | 1597 | 41011 | 00:21:40 |
| 100M/Full | 4359 | 3331 | 0 | 2037 | 603 | 00:23:55 |
| 11M/54M | 42708 | 28610 | 0 | 41603 | 1546 | 00:23:43 |
| 1020 kbps | 606 kbps |
| 46 db | 30 db |
| 15 db | 16 db |
on ‎22-09-2011 02:43 PM
Hi flumpy,
Welcome to the forum and thank you for posting your stats, you've mentioned that they have been taken from your master socket, does your master socket look like the socket below, if so can you please unscrew the faceplate and connect only the microfilter and broadband and re post your stats, as this will allow us to see if the speed will improve
on ‎22-09-2011 05:14 PM
| PPPoA | 668959 | 769893 | 0 | 644 | 4020 | 41:59:09 |
| 100M/Full | 248739 | 170026 | 0 | 1991 | 216 | 42:01:24 |
| 11M/54M | 564057 | 535435 | 0 | 2199 | 497 | 42:01:12 |
| 47 db | 29 db |
| 14 db | 15 db |
Hi,thanks for the reply,yes I do have the same master socket as shown,I have plugged the micro filter into the test socket and the above are the stats.I have noticed that Sky have set my speed to 1mb limit,where as before i had up to 3mb,this is a bit of a joke.It takes ages to download anything as for playing online games they lag all over the place,any advice please,thanks
on ‎22-09-2011 05:30 PM
Hi flumpy,
There isn't much of a difference between your master and test socket stats. As your noise margin is 14db then we should be able to improve your speed in order to have this done you would need to contact us
on ‎22-09-2011 06:46 PM
Hi,contacted a Sky service agent and he done tests on the line and has now put it back up to 3mb,thanks for all your help.
on ‎22-09-2011 06:57 PM
I was getting speeds of .5mb, finally called Sky to have the line reconfigured (my noise margin was 12.1). Only took a minute to for Sky to change and now getting speeds of over 4mb.
Very happy with Sky's service - thanks!
on
‎25-09-2011
01:04 PM
- last edited on
‎25-09-2011
01:11 PM
by
Buddica.
can you help its really slow
Firmware Version
| V2.02.44 |
ADSL PortMAC AddressIP AddressNetwork TypeIP Subnet MaskGateway IP AddressDomain Name Server
| 00:24:b2:47:5a:ea |
| 192.168.0.1 |
| On |
| 255.255.255.0 |
ModemADSL Firmware VersionModem StatusDownStream Connection SpeedUpStream Connection SpeedVPIVCI
| 7.03.01.66 |
| Connected |
| 1888 kbps |
| 416 kbps |
| 0 |
| 38 |
Wireless PortName (SSID)RegionChannelWireless APBroadcast Name
| Europe |
| 11 |
| Enabled |
| Enabled |
‎26-09-2011 01:47 PM - edited ‎26-09-2011 01:48 PM
Hi webba91 ,what line speed were you given by sales or our Web site (estimated access line speed)? If you are having problems with your speed please try the troubleshooting here. If this does not help I would advise trying your router in your test socket if you have one, or in the master socket on it's own if you don't, with a different filter and posting the router statistics you see there along with the statistics from your current configuration.
