Archived Discussions
This page has been archived
The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference. Learn more about this message
Getting There
Jean+Carole
Sky remote won't work tv volume
Have just bought new remote and was hoping it would cure the problem we had with the old one. It used to operate the volume then stopped. It's a Toshiba tv and have programmed remote using the code 0156. Is there another code I should be using? Husband about to throw it across the room! Help!
Please do not post any personal details or account information. Please use plain text.
Super User
caesarome
Re: Sky remote won't work tv volume
Try taking one battery out and then hold down the select button for 60 seconds. When the minute is up put the battery back into it and press the big sky button. Does it work the volume now ?
__________________________________________________________________________________________.
I do not work for Sky.
Getting There
Jean+Carole
Thanks for the suggestion, tried that and I'm afraid it didn't work. Any other ideas??
Staff
Peter-Ed
Hi Jean+Carole,
Thanks for posting,
You can follow this link and see if this will help you http://goo.gl/ybZok
Many Thanks,
Getting There
Jean+Carole
Thanks so much! Seems to have worked!
