Showing results for
Search instead for
Do you mean
Help
Help
Archived Discussions
This page has been archived
The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
Learn more about this message
Visitor
Andrew+Warriner
Sky remote (8R) with Pioneer AV Receiver VSX-527K
Hi,
I've read a good thread here ... http://helpforum.sky.com/t5/Sky-HD/Sky-Remote-Rev-9-code-for-Pioneer-AV-receiver/td-p/422507 but i'm still not having any luck with the Pioneer AV receiver VSX-527K.  Does anyone know a working code for this unit and the fact my remote is only rev. 8R, will that make a difference? and if it does, how do I get a newer remote that will work?
Thanks,
Andrew
Stay Safe: Don't post any personal details or Sky account information. Plain text only in this box.
Retired Staff Member
kirsty+d
Re: Sky remote (8R) with Pioneer AV Receiver VSX-527K
Hi Andrew+Warriner,
Welcome to the Help Forum and thank you for contacting us.
Can you confirm as well as checking out that particular thread, that you have seen the on-line tool for remote codes? This requires the necessary information to be input and does 'cater' for differing remote models and versions.
Please let me know if this has been of any help?
Regards,
Visitor
Andrew+Warriner
[ Edited ]
Yes, correct, I tried the online tool first (which suggested 0039, 0788, 0198 which didn't work) so then I searched the forum.
Anne-M
Hi Andrew+Warriner,
The codes that are available for a pioneer amp are:
0328, 1051, 0317, 0214, 1151, 1212, 1117, 1217, 1312, 1487, 0851, 1297, 1317, 1651, 2132, 1963 and 1851.
Please note that the codes in bold require the latest version of remote control, this is the SkyRev.9F. You can find the version of the control by looking on the stickers inside the battery compartment.
To programme the remote:
  • Turn on AV amplifier.
  • Point remote control away from AV amplifier and press TV button.
  • Press and hold down the select and the 0 buttons until the red light at the top of the Sky Remote Control flashes twice.
  • Input first 4 digit code.
  • Point remote control at the amplifier.
  • Press the left arrow button on the remote control to try and switch the AV amplifier into standby.
  • If AV amplifier switches to standby then the other AV Amplifier functions should also work and the correct code has been selected.
  • If AV amplifier does not switch to standby, or all AV functions do not work correctly, then repeat the process using any other available codes for the brand.
If one of the codes supports your amp then some or all of the features below may be controlled by pressing tv then the following buttons:
RCU Button
AV Amplifier Function
What does this button do?
Left Navigation
Standby
Switches the unit onto Standby, or back out of standby.
Right Navigation
Mute
Mutes the sound from the AV amplifier.
Up Navigation
Volume Up
Switches the AV Amplifier volume up.
Down Navigation
Volume Down
Switches the AV Amplifier volume down.
Rewind
Prologic On/Off
This switches the Dolby ProLogic functionality on or off.
Fast Forward
Effects On/Off
This deals with amplifier generated effects such as Stadium, Disco etc.
Stop
Input Select
This will select each of the inputs into the AV Amplifier in turn.
Play
On widescreen tv Zoom
The Zoom function on a widescreen TV stretches a picture to fit as much of the screen as possible.
An additional option allows the Volume up, down and mute mode of the TV to be swapped with the Volume up, down and mute of the Amp. This means that in normal operation if the TV speakers are not connected and all sound is sourced via the Amp it will not be necessary to press the TV button first to adjust the sound of the Amp.
After changing this option volume up, down and mute for the Amp will be available in both Sky and TV mode on digibox, Sky+ and Sky+HD remote controls and the TV sound controls will be available on the up, down and right buttons when the remote is inn TV mode. Here is the procedure on how to swap the functions:
Setting the Sky remote control to swap the vol up, down and mute buttons.
1) Press 'Select' and '1' together and hold down until the LED on the remote control flashes twice.
The remote will now control the sound of the Amp when Volume up, down or mute are pressed and the TV sound if arrow up, down or right are pressed
**To reverse the setting and return to normal operation
2) Press 'Select' and '2' together and hold down until the LED on the remote control flashes twice.
Can you let me know how you get on?
Thanks,
Anne
Community Coordinator
Community Welcome, Hints & Tips
Sky Help Centre http://www.sky.com/help
New to the forum? Click here
Tagging your posts and others with relevant key words is another way to help,
it also counts towards forum rank.
Visitor
Andrew+Warriner
Hi Anne,
Thanks but this is the same text that was in the thread I quoted to you.  Since I only have a 8R revision remote and not 9F then I can only use half the codes (none of which work) and I guess I can't use the codes in bold without a 9F revision remote.  So how/where do I get a 9F remote which will hopefully work the latest codes?
Thanks,
Andrew
Anne-M
Hi Andrew+Warriner,
You can puchase a new remote control through our accessories website (although I cannot guarantee that a Rev9.F would be sent as we are not aware of what the stock are like). The only way you could get get this is to purchase this from an independent retailer?
Prior to purchase, do you know anyone with a Rev9.F remote control that you could borrow to try the codes out?
Thanks,
Anne
Occasional Visitor
SquishySaru2
Hi Andrew,
I have a sky 9F control and VSX-527K and I just went through the motions.
1651
Worked for me - Full control.
Looks like I can retire my Harmony One now........
Anne-M
Hi SquishySaru2,
As this is your first post I would like to welcome you to the community :smileyhappy:
I just wanted to take a minute to thank you for letting Andrew know what code you have found that gives you full control. I hope that your feedback will help other customers who may be looking for a solution.
Thanks,
Anne
