Sky plus hd light on router not on permanently
Runner
Post 1 of 29
I can download on demand content.Completed loop test on Ethernet cable it is fine and checked all settings on sky plus box but still hd plus light will not come on new sky router.
Director of Photography
Post 2 of 29
Re: Sky plus hd light on router not on permanently
HD light on Router will only light up if wired connection not if using wireless connector
Runner
Post 3 of 29
Yes wired connection with working Ethernet cable yet the light does not come on despite downloading on demand services okay.tried a friends router too and light still did not come on
Post 4 of 29
Strange! Light should be permanently illuminated and flash when downloading content. Have you tried powering everything off at mains for 5 mins then turning back on ?
Runner
Post 5 of 29
Yes and just completed planner rebuild and hd box software update too ! Must be fault with box then I guess ..
Runner
Post 6 of 29
I have exactly the same problem all irks ok but light isn't on
Retired Staff Member
Post 7 of 29
Hey All,
I have had a wee read over this thread and can see that the light is not lighting up for a few of you, is this causing any technical issues with your services? Or do you just want it to light up?
Cheers
Runner
Post 8 of 29
Yes want light to come on so at a glance you can see what on demand is doing and that router is working ok ...flashing light useful !!
Post 9 of 29
Hi thunderbirds078,
Thank you for getting back in touch with us about the light on your Sky Hub not lighting up when connected to your Sky+HD box.
Can you confirm if you have tried all the ethernet ports on the back of your Hub?
If you can reply to my post to let us know.
Runner
Post 10 of 29
Yes did that no luck...
Post 11 of 29
Hi thunderbirds078,
Thank you for trying this.
Can you let me know if the ethernet ports light up when they are in use?
Runner
Post 12 of 29
Yes they do - each one-also checked ethernet cable by plugging BOTH ends into router - both ends light up too
Post 13 of 29
Hi thunderbirds078,
Thank you for getting back in touch. Are you having any other Internet connection issues?
I look forward to hearing from you.
Runner
Post 14 of 29
no all working
Post 15 of 29
Hi thurderbirds078,
Thank you for replying. Just so I understand all other devices are picking up your Sky Broadboard Connection except your Sky box, when connected via the SkyHub (by Ethernet cable). Is this correct?
Recommended Threads
11-04-2018 05:39 PM
a month ago 01:07 PM
18-03-2018 02:25 PM
02-04-2018 11:08 PM
24-04-2018 08:32 PM
