Sky Remote Codes
Runner
Post 1 of 10
Sky Remote Codes
Hi,
I've just bought a HG model NB2430A Sound Bar and I am trying to connect it to my Sky Remote so I can control the volume. But I can't find the right code. I've tried the codes listed on the site for NB2530A but they're not compatible. Can anybody help ?
Thanks in advance
Camera Operator
Post 2 of 10
Re: Sky Remote Codes
Retired Staff Member
Post 3 of 10
Hi Soda+Terminator
Welcome to the Sky Community!
Sorry for the late reply and hope you're well.
Did the link above help resolve your issue?
Thanks,
Kristi
Community Coordinator
Runner
Post 4 of 10
Not really. I already have the LG Tv code & it works but the LG Sound-Bar is a different code & set up from what I've been told but I can't find it.
Camera Operator
Post 5 of 10
Post 6 of 10
Hi Soda+Terminator
Thanks for the reply.
The codes that are available for a for LG amplifiers are:
1321, 1552, 2225 and 2417
Thanks,
Kristi
Runner
Post 7 of 10
I've tried the four codes but still no joy. My LG model is a NB2430A but the one mentioned in the other link is for the NB2530A model. That may make a difference. Any other ideas ?
Post 8 of 10
Hi  Soda+Terminator.
Thanks for your post there and sorry to hear that you are having such issues with your Sky Remote Codes.
Could I please ask if you have tried resetting the Remote at all?
1.Firstly you would need to remove the batteries.
2.You need to then press and hold down 'select' for at least 60 seconds before releasing it.
3.Then re-insert the batteries ensuring plus and minus signs are matched correctly.
4.Press Sky and The LED should flash.
5.Press TV Guide.
Please post back and let me know how you get on.
many thanks,
Runner
Post 9 of 10
Hi
Still no joy. I did the reset then tried the 4 codes i.e. Tv button followed by select & 0 then the code and left arrow button to test for standby. I've even tried select & red button then the codes but nothing re the sound-bar connecting to the remote. Apart from hitting with a lump hammer have you any other ideas?
Post 10 of 10
Recommended Threads
