Archived Discussions
This page has been archived
The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference. Learn more about this message
Getting There
Sam+Jr.
Remote Control Code for LG LS575T
Can anyone help in setting up my SKY remote control rev.8 to work with my LG LS575T smart tv? Any help appreciated. Thanks.
Please do not post any personal details or account information. Please use plain text.
Retired Staff Member
GarryC
Re: Remote Control Code for LG LS575T
Hi Sam+Jr.,
I have had a look for you and have found the following codes may work for your TV:
0206 1206 1293 0851 0857 1665 1174 1176 1219 1280 0904
If you can give these a go, and let me know how you get on.
Thanks,
Getting There
Sam+Jr.
I tried the codes - some of them work to set the volume BUT they dont work for changing channels.
Staff
Anne-M
Hi Sam+Jr.
Can you provide the whole model number for the TV as it looks like there is a few numbers missing in front of LS575T? This will help us to see if we have a code available for you.
Thanks,
Anne
Community Coordinator
Community Welcome, Hints & Tips
Sky Help Centre http://www.sky.com/help
New to the forum? Click here
Tagging your posts and others with relevant key words is another way to help,
it also counts towards forum rank.
Getting There
Sam+Jr.
The full number is LG 42LS575T-ZD 42in. smart tv. Thanks.
Staff
Anne-M
Hi Sam+Jr.
We do not have an exact code available for this model of TV, however there have been some suggestions using our online tool?
Can you try the following codes for me and let us know how you get on?
0065, 0742, 0634, 1293, 1176, 0206, 1868, 1451, and 2210.
Thanks,
Anne
Getting There
Sam+Jr.
Again,
Staff
Anne-M
Hi Sam+Jr,
Can you try entering the code 999 into the remote control? This will remove any potential codes that are in the remote. Are you now able to use the remote to change channel - if not, please remove one battery, hold the select button forr 60 seconds and reinsert the battery. Try changing channel now.
Thanks,
Anne
Getting There
Sam+Jr.
OK, I did that. Now the volume works & it displays the channel number on the screen BUT the channel DOESN'T actually change on the TV.  Thanks for your help.
Super User
caesarome
Try reprograming it with those codes again.
__________________________________________________________________________________________.
I do not work for Sky.
Getting There
Tchelo
for reference as this post is quite old.
1868 is the code that worked for my ls575t.
press TV > then Select + Red until red light blinks twice. Type in 1868 and it will blink twice.  Select again and it will be all.
cheers
I'm New Here
Julilly69
Thanks this worked for my tv. So glad been looking for months. Cheers
