Archived Discussions
This page has been archived
The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference. Learn more about this message
Getting There
Sammy100
On Demand Wireless Connector + BT Home Hub
As hard as Itry this will not connect. The local connection is ok but service connection FAIL. (yes password is lower case)
Sjy says language on BT Home Hup needs changed from WEP to WPA PSK or vice versa. Bt changed my security settings from WPA and WPA2 to WPA only but no help. Don't know where to go now as BT say they can't help.
Please do not post any personal details or account information. Please use plain text.
Super User
Annie+UK
Re: On Demand Wireless Connector + BT Home Hub
Just as a test try turning the Home Hub Wifi security OFF temporarily and see if it connects then. This will show if the WiFi security is the place the connection is having trouble with.
I find the Home Hub Wifi to be vary dodgy so use an Edimax EW-7416APN attached to the HH for WiFi connectivity, it has better range and a more reliable connection.
Annie..........    Sky customer since 1989.
If someone helps you please click the thumbs up icon and/or accept as a solution, where appropriate. Thank you.
Getting There
Sammy100
No that didn't work either
Super User
Annie+UK
Try this on the HH:
Settings >> Advanced settings >> Broadband >> VPN >> Port Clamping Enable >> Yes
Getting There
Sammy100
No that hasn't worked either. :smileysad:
Super User
Annie+UK
All I can think to try is reset the HH and Wifi connector to factory settings.
Getting There
Sammy100
I might have to go back to that. Sky did say they were getting a lot of calls and the vast majority were problems with the BT hub
Getting There
BurningRed
I had the exact same problem,i left it for a few days and the tried again and it worked see my post.
http://helpforum.sky.com/t5/On-Demand-Catch-Up-TV/Sky-HD-box-not-connecting-to-BT-broadband-via-ethe...
Getting There
Sammy100
Thanks for that i will give it a go.
Getting There
jackel-cz
I am having the same problem as everyone else on this forum. I keep getting "service connection fail". I have read through this and other forums and tried the solutions put forward my mods and members but to no avail. I am using a bthome hub 3 on infinity with skys wireless connector.
Getting There
Sammy100
I sent a complaint in asking for a refund. Someone got back to me quickly and spent another hour going through it again but it still wouldn't work. So they are sending me a new one as they said this one might be faulty but have promised a refund if it still won't connect.
Getting There
Armo100
I have sky router so no probs for me. My friend has a BT home hub. Its taken a week of trying everything but THIS WORKS. Mega happy whoop whoop
Getting There
bRYSON2013
I have BT Home Hub 3 and am trying to connect via sky wireless connector (arrived today). Managed to get local connection ok and IP but service connection has failed so cannot get the ondemand stuff, I have read all through this article and tried the lot but still not working,any suggestions?
Getting There
Sammy100
I should have updated on my situation. Sorry. I was sent a new box and when i connected it I had the same problem of system fail so just gave up in disgust. However, a few hours later - and in a better frame of mind - I went back and tried again and it worked !!!! The sky helpdesk said I obviously had a faulty box originally.
Staff
Tricia07
[ Edited ]
Hi Sammy100,
Thanks for getting back and letting us know that you have this up and working.
Enjoy the On Demand service and look forward to your future posts:smileyhappy:
