Help .. remote code for Panasonic Viera TX-L42E5B needed ?
Answered
Go to Answer
Runner
Post 1 of 13
Hi everyone, I'm hoping some bright spark here will have the answer for me. I've just upgraded my old Sony pre-HD tv to a nice new Panasonic TX-L42E5B.
I'm trying to set the Sky HD+ remote to recognise the new TV but Sky don't have a code for the model and the ones they suggest that I try don't work.
Remote HD rev 9f
I have tried 1352, 0471, 1944, 0584, 2154, 1664, 0678 and 2505.
Answer
Answer
Runner
Post 3 of 13
Re: Help .. remote code for Panasonic Viera TX-L42E5B needed ?
Many thanks for your help .. I finally realised I wasn't quite following the SKY instructions properly after trying a few of your codes. I wasn't holdong down the SELECT + RED button long enough to get the two red light flashes (doh!).
The code 1664 worked.
Thanks for your time.
Executive Producer
Post 2 of 13
Try these as well. 0051  0878  2058 1678 7590 0512 0302 0254
Answer
Runner
Post 3 of 13
Executive Producer
Post 4 of 13
Glad it's sorted.Smiley Very Happy
New Viewer
Post 5 of 13
Thanks, 0878 for Panasonic TH-37PX80BA
Runner
Post 6 of 13
0878 for Viera TX-L32E30B
Runner
Post 7 of 13
0678 worked for the TXP42G30
New Viewer
Post 8 of 13
Hi
I have a problem with the SKY + remote for my Panasonic TQFF139. codes 0678 , 0878 and 1678 all work together with the select and red button to allow me to use the volume control but still cannot change channels using the remote. Can anyone help?
Viewer
Post 9 of 13
Holding down the red and select buttons for long enough sorted this out for me. Thanks for the tip!
And code 1664 worked first time.
Runner
Post 10 of 13
Code is 0678
New Viewer
Post 11 of 13
Thanks worked Smiley Happy
Staff
Post 12 of 13
Sorry to see you're having difficulty with your Sky remote changing channels Gorgeous+Girlie, I'd like to help Smiley Happy
Once you've entered the code in to your remote, make sure you press the Sky button at the top of the remote as this should kick in the Sky part of the remote again.
Once you've done this, you should be able to change channel and use the TV functions such as volume.
Give that a go and let me know how you get on and I can assist further if required.
Thanks,
Runner
Post 13 of 13
Lord knows why Sky don't tell you this but if you have a pre-version-4 remote, just omit the first zero. 678 worked perfectly for my brand new top-of-the-range Panasonic TX-P50VT65B.
